I bought zero footprint portable 7.4 kw ev charger.
It's not charging. The mcb gets tripped in 5 10 minutes.
Mcb is c40
.. wire used was 6mm
jaidev
General
7.4 kw charger getting stopped
Comments (13)
DeepakT
Can you put another picture of the open distribution box 'Harson'?
Asheesh
Set amps to 25 ..
What's your total meter load btw ?
jaidev
@Asheesh
Ohk
I will try and than i would tell.
Will a good stabilizer can work here?
Asheesh
@jaidev
Stabilizer is considered if the charger isn't able to handle the voltage and one is sure of the issue
Rakesh
I see you informed 6 sqmm. Also check the terminals if they are loose. Does your charger support lowering the power of amps? If yes try lowering amps as well and see if it still trips
jaidev
@Rakesh
Okay I will try. Yes zero footprint support it. But i don't know how to lower it.
Page
1
of
2
